10kg payload
A project log for K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
robin-frjdRobin Fröjd 05/16/2021 at 22:121 Comment
so tonight I have been playing around with payload testing. Mostly to get some more knowledge and data of consumption and  to learn more about the robot capabilities. I am also interested to check this because my plan is to have an arm mounted on top which also comes in at around 8kg.
the UP Xtreme is included in the consumption data and have an estimated 0.6A consumption on average. The robot itself is aproximately 17kg net weight.
Voltage is configured at 36v.
Payload 3kg = 1.67A
6kg = 1.91A
10kg = 2.35A (video)
#quadruped #quad #robotics #ros #leggedrobotics #mjbots https://t.co/Lpj1twf4yF
Cheers
[deleted]
Robin Fröjd wrote 05/17/2021 at 14:23 point
Thanks
