The final update design has been partially assembled and a USB C connector had been used in place of the micro USB connector.
The tiny 0.49" OLED display has also been fitted and all wiring has been done.
Will be powering up the TinyPICO NANO next to make sure everything functions as it should
Ayo Ajayi
