Motor & movement
A project log for CNC machine V3: Mill
The third version of my CNC machine I’m making, all the pervious ones had serious issues with stability.
yuhyuh 01/30/2021 at 15:490 Comments
Lay-out work for the motor attachment on the Y axis
Motor mount cut out of 2mm aluminium
Let paint dry
I don’t have the real blue paint that most machinists use, but a permanent marker (and some sanding afterwards) will do the job!
X axis motor mount
Y axis motor mount paintjob
For holding the nut in place
Nut holder for the y axis: bent and painted
Wooden bit will keep the nut from spinning
X axis motor mount
Z axis motor mount
Z axis motor mount installed
I upgraded the mount for the bolt
Also the X nut holder is improved
Z movement
