It looks like with 120 ohm resistor, I have introduced excessive termination that led to errors in CAN transmissions. I had to unsolder termination resistor from my board and trim my cables to work properly as CAN stub.
Enclosure arrived today, so I have mounted everything inside.
It requires more testing this time, but I hope that issue is fixed.
