I'm starting to play with circuitjs. You can try a first playground here. It's still buggy and incomplete but you get the idea of the actual complexity.
For now I have dropped the requirement for B to avoid the 00 state, as well as the XOR. When the circuit detects A=B, it outputs an "error" status bit and forces the update: this makes the circuit self-correcting after a couple of cycles, like the old 4017.
This changes the boolean equations that I already found the other night, and I must redesign them. There are only 64 cases to consider, with many possibilities, but few are minimal.
The following lookup table shows the values injected into B, since A is usually a copy of the old B.
| S:
A: B: | 00 01 10 11
00 00 | R:01,10,11...........................
00 01 | A:10,11 B:10,11 x x
00 10 | A:01,11 x B:01,11 x
00 11 | A:01,10 x x B:01,10
01 00 | B:10,11 A:10,11 x x
01 01 | R:00,10,11...........................
01 10 | x A:00,11 B:00,11 x
01 11 | x A:00,10 x B:00,10
10 00 | B:01,11 x A:01,11 x
10 01 | x B:00,11 A:00,11 x
10 10 | R:00,01,11...........................
10 11 | x x A:00,01 x
11 00 | B:01,10 x x A:01,10
11 01 | x B:00,10 x A:00,10
11 10 | x x B:00,01 A:00,01
11 11 | R:00,01,10............................
x : no modification
R: error (A=B) => B=new (A=B implicit, harmless)
A: Match A => A=B, B=new
B: Match B => B=new
In all cases, the output A is either input_A or input_B. So there is nothing to compute on this part.
The only thing to compute is the new_B : 2 bits depending on 6 input bits. Make it 7 for the random input. And an 8th input for MRU mode but it doesn't affect the computation of new_B. And the table shows that the possible outputs only depend on the A and B inputs (4 bits only).
Condensed array:
A: B: A^B | Possible values: ----------+------------------ 00 00 00 | 01,10,11 00 01 01 | 10,11 00 10 10 | 01, 11 00 11 11 | 01,10 01 00 01 | 10,11 01 01 00 | 00, 10,11 01 10 11 | 00, 11 01 11 10 | 00, 10 10 00 10 | 01, 11 10 01 11 | 00, 11 10 10 00 | 00,01, 11 10 11 01 | 00,01 11 00 11 | 01,10 11 01 10 | 00, 10 11 10 01 | 00,01 11 11 00 | 00,01,10
All entries have at least 2 possible outputs, to be selected by a random bit.
The possible outputs must not be A or B so A^B is a very interesting value.
The table shows that ~(A^B) is a valid value for most entries except for B=11, where A^B is valid, so we have something here! A NAND and a few XOR will work.
It seems that my initial boolean analysis was wrong.
A: B: A^B /A^B | Possible values: ---------------+--------------------- 00 00 00 11 | 01,10,11 00 01 01 10 | 10,11 00 10 10 01 | 01, 11 00 11 11 00 | 01,10 01 00 01 10 | 10,11 01 01 00 11 | 00, 10,11 01 10 11 00 | 00, 11 01 11 10 01 | 00, 10 10 00 10 01 | 01, 11 10 01 11 00 | 00, 11 10 10 00 11 | 00,01, 11 10 11 01 10 | 00,01 11 00 11 00 | 01,10 11 01 10 01 | 00, 10 11 10 01 10 | 00,01 11 11 00 11 | 00,01,10
There is obviously a requirement to use a "diagonal" of the squares (even permuted) because focusing on a column would create an unacceptable bias of the sequences, particularly if 11 is constantly output (except 00 when A=11). So both bits should be inverted when A!=11.
But there is more happening with B=11 that requires special care.
In the new circuit, A=00 B=11 and A=11 B=00 both resolve to the unwanted value 11.
For A=00 B=11 this creates the forbidden state 11 11 when the desired set S is also 11. This case is only 1/4th and the result can later be recovered because the next state will become 11 00. Adding an extra gate can avoid the copy of B into A2.
For A=11 B=00, the forbidden state 11 11 is also output when S=00.
A few more gates (A[0] xor A[1], NAND3 and XOR3 replacing XOR2) solves this and we get :
- A=00 B=11 S=00 => A2=11, B2=01
- A=11 B=00 S=11 => A2=00, B2=01
And that's it.
A: B: | value: ------+--------- 00 00 | 11 00 01 | 10 00 10 | 01 00 11 | 01 01 00 | 10 01 01 | 11 01 10 | 00 01 11 | 10 10 00 | 01 10 01 | 00 10 10 | 11 10 11 | 01 11 00 | 01 11 01 | 10 11 10 | 01 11 11 | 00
The map is slightly biased toward 01 but that's fine.
- 00: 3×
- 01: 6x
- 10: 4×
- 11 : 3×
I'm sure there are some other ways to implement this, depending on the technology. I tried to minimize the number of gates but the bias towards 01 is reduced with one more gate or two.
Anyway you can play with it at home.
Yann Guidon / YGDES
