I did some major code refactoring for the logging function. Now it supports raw packet data printout. Serial output and logging are asynchronous. There is minimal impact on PD timing when logging is enabled.
A project log for PD Micro - USB-C PD3.0 PPS Trigger
Arduino-compatible ATMega32U4 board with USB-C PD3.0 PPS Trigger
