My private notes ;)
My steps:
Write image: 2021-05-07-raspios-buster-armhf-lite.img
copy to boot:
empty file ssh
wpa_supplicant.conf
country=SK
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="mynetwork"
psk="mykey"
add in to config.txt
[all]
hdmi_group=2
hdmi_mode=87
hdmi_cvt=320 240 60 1 0 0 0
hdmi_force_hotplug=1
dtparam=audio=on
start_x=0
dtoverlay=audremap,pins_18_19
dtparam=i2s=on
dtparam=spi=off
display IP address
ifconfig
via ssh
Login: pi
password: raspberry
$ sudo raspi-config
SET AUDIO > headphones
boot console autologin pi
DISPLAY SETUP
sudo apt-get update
sudo apt-get install cmake
sudo apt-get install git
cd ~
git clone https://github.com/bobricius/fbcp-ili9341.git
cd fbcp-ili9341
cd fbcp-ili9341/build
rm -r *
cmake -DST7789VW=ON -DGPIO_TFT_DATA_CONTROL=25 -DGPIO_TFT_RESET_PIN=27 -DSTATISTICS=0 -DSPI_BUS_CLOCK_DIVISOR=6 -DUSE_DMA_TRANSFERS=OFF -DDISPLAY_ROTATE_180_DEGREES=ON ..
make -j
sudo ./fbcp-ili9341
Extra toys
sudo apt-get install mc
sudo apt-get install w3m
sudo apt-get install mpg123
KEYBOARD SETUP
cd ~
git clone https://github.com/bobricius/gpiokeyboard.git
pip3 install python-uinput
For autorun on startup put this line before exit 0
in your sudo nano /etc/rc.local
sudo /home/pi/fbcp-ili9341/build/fbcp-ili9341 & sudo modprobe -i uinput & sudo python3 /home/pi/gpiokeyboard/gpiokeyboard.py & sudo setfont /usr/share/consolefonts/Lat2-Terminus20x10.psf.gz &
