After reconciling requirements, started work on quick solvers.
The plan is to implement at least:
- Quadratic equation solver,
- Cubic equation solver,
- Gain-offset solver,
- Generic root search (for any equation defined in program memory),
- Numeric integration (for any equation defined in program memory),
- Forward probability solver for normal distribution,
- Reverse probability solver for normal distribution.
Below is the approximate sequence for cubic equation Ax^3+Bx^2+Cx+D=0:
1. Enter A into T:, B into Z:, C into Y: and D into X: by any convenient method:
2. Press [F],[A],[√]
3. Read the result
https://github.com/myak555/MK-52_Resurrect/blob/main/MK-52_Sample_Programs/0017_Cubic_Equaton.MK52
but loading a program via File Manager is too time-consuming.
ptrav
