Minimalist simple pocket sized digital photo frame
Wemos_DIY_Digital_Photo_Frame.inoArduino codeino - 8.29 kB - 01/13/2021 at 02:40 |
I. Hardware requirements:
II. Software requirements:
The code has been tested and found to be working with the following versions of software
The connections have been made in the Breadboard section of the Fritzing software as shown above. Mind the “Lite” pin connection, without which the backlight will not work.
In the PCB tab of the Fritzing software, the PCB size and connections can be finalized. This design is difficult to be fabricated as a single layer board, hence two layers are being used. The pins have been labelled as the silkscreen print. The final PCB design has been shown below. You could use the “autoroute” function if you find it difficult to route the tracks.
