I've not been working on this project for awhile (the kitchen took precedence). I've traced the doorbell wiring to make sure that I hook it up to my circuit board correctly:
white - power wire (screw 1 on the front)
red - high chime
brown/red stripe - low chime
yellow - screw 3 on from (switch wire)
grey - med chime
orange - ground?
sky blue - to chimes
brown - power wire (shared with white)
black - secondary chime wire.
Dark grey - neutral wire screw 5 on front
