So the PCB's showed up, and everything soldered up perfectly the first time, so that's good. Circuit works, and I was able to throw simple ESPHome code at it and make it function. All that was easy and perfect...
But then, I went to test it in the real world, and that's when things were less than ideal.
Right now I have one cartridge fully used, and one fully new. I put the sensors in the 3d-printed clips, attached, and the readings were garbage. Same on both, or close enough to same that it didn't matter. If I swapped the sensors around I just ended up with the same value over and over, or indistinguishable differences....
But this totally worked when I taped the sensors. So I tried that again just for sanity, yep, taped sensors right to the cartridge, and it works.
My next thought was that I have the sensors too far from the cart now. I have a 1cm tube the sensor shines down in the holder, and maybe that's too long, so I shortened it to about 1mm. Still no good.
Right now my current thinking is that the black PLA is messing up the readings. I would have thought black was the way to go, but maybe not. I've just re-printed in cool white PLA, going to try that and see if I get different results... here's hoping. I know this works, I just have to figure out how to mount it now.
