I redesigned the bracket for the ring light of the cameras over the past few days. So a diffuser made of milky acrylic glass can also be clipped into the LED ring. Hopefully this will scatter the light a bit and avoid glare.
After I finsihed this build somebody told me that commercial PNPs use cone shaped led rings to avoid this kind of reflections. So I decided to test this design first. If needed I will have to redesign this. Lets see. :)
Some pictures of it:
