Release 1.10 is the first release we provide as simple to install UF2 file. To install, pull the reset switch on the left side of the Wio Terminal twice. A new drive named
ARDUINO will appear in your finder / explorer. Just drag the file
passwordvault-v1.10.uf2 there to install it.
The user features are identical to v1.8 which are described in our wiki.
