It would be easiest to use a car lift to take down the battery, unfortunately I don't have access to one. So I've helped myself using stacked euro pallets and a forklift. The Mitsubishi dismantiling guide I've found on the internet also helped a lot to take down the battery. It's quite some hours of work.
