For some projects (e..g pxlBlck_digitClock) I needed some seven segment digits. The iterative design process resulted in the shown design.
A seven segment digit that uses 14 WS2812 LEDs (two per segment) to display the numbers from 0-9. Of course more digits can be combined to display longer numbers.
Another example of this is visible in my pxlBlck project log here:
https://hackaday.io/project/175825-pxlblck-an-iotsmarthome-notification-systemThe
Build guide incl. STL files is available here:
https://nerdiy.de/en/howto-elektronik-sieben-segment-ziffer-pxldigit-aus-ws2812-leds-bauen/
Small insight into the first usecase
The same STL was also used for the pxlBlck_digitClock
ACROBOTIC Industries
Peter Lehnér
kevarek
Very nice, I suggest painting inside of cells with silver or white paint or lining with aluminium foil. It will disperse light a little more. Having a little more depth will help too.
