Missing Tripod Quick Release Jamboree!
Designed & printed the three quick release styles missing from a few Goodwill Store tripods that have been invested in over the years.
0 followers
Figured was time to update the ~450MHz Yagi Antenna that's a cost effective made in the USA clone of a Chinese antenna found on Aliexpress. https://www.instructables.com/-450MHz-Yagi-Antenna/
With a new (used, like I'm going to buy new) MPSM V2 at hand, I decided I needed to print a quick release for the Slik U9000 that was a specific design for the 1" square aluminum tube of the antenna.
First, I figured I'd start off with the other two of the three tripods that were missing quick releases and either remix or make from scratch.
Radio Shack RST-84V, Vanguard RST-216 and the Slik U9000 quick release variations are what resulted. These quick releases most likely have other tripod makes and models where they can be used.
I know with the Slik the 6122 is the quick release model and for the Vanguard the QS-05/QS-06 are the quick
GoPro_QS-05_quick_release_per_drawing_measurements.4.stl
Standard Tesselated Geometry - 396.37 kB - 01/22/2021 at 10:55
Download
Slik_6122_quick_release_Plate2.stl
Standard Tesselated Geometry - 130.94 kB - 01/22/2021 at 10:55
Download
GoPro-ZipTie-Mount3_top_Radio_Shack_RST-84V_guick_release_60deg_minus_top.2.stl
Standard Tesselated Geometry - 366.59 kB - 01/22/2021 at 10:55
Download
Radio_Shack_RST-84V_quick_release_60deg_minus_top.2.rsdoc
rsdoc - 202.78 kB - 01/22/2021 at 10:55
Download
GoPro-ZipTie-Mount3_top_Radio_Shack_RST-84V_guick_release_60deg_minus_top.2.3mf
3mf - 94.39 kB - 01/22/2021 at 10:55
Download
View all 11 files
