7" LCD for Raspberry Pi CM4 CMIO
7" 1200x1920 IPS MIPI DSI display for your Raspberry Pi CM4 CMIO board
Most of high resolution LCD displays for Raspberry Pi use HDMI connection and implement HDMI to LVDS or HDMI to MIPI DSI converter circuit. Newest Raspberry Pi CM4 exposes 4 lane MIPI DSI connector, allowing to directly connect LCD panels for mobile applications.
One of these panels is JDI LT070ME05000 - 7" 1200x1920 IPS MIPI DSI panel, used in Google/Nexus 7 tablet 2013 edition. It's 8 years old panel, but still looking good for DIY projects in 2021 and available starting at ~$20. Driver for this panel is a part of Linux for years and run successfully at Raspberry Pi CM3. It wasn't popular that days, since CMIO board for Raspberry Pi CM/CM3 was good enough for developers, but definitely missing features and connectivity that makers expect to see out-of-the-box.
Long story short - only simple adapter board needed to make this panel work with CM4 CMIO board and sources/instructions are published in our GitHub page
We also encourage CM4 baseboard developers to use Raspberry Pi 22 pin DSI connector to make more DSI panels available, just like we did in our CM4Ext Nano, worlds smallest CM4 baseboard
  • 1 × Raspberry Pi CM4 Raspberry Pi Compute Module 4, any variant
  • 1 × Raspberry Pi CMIO Raspberry Pi Compute Module IO board
  • 1 × JDI LT070ME05000 LCD panel
  • 1 × 22 pin 0.5mm pitch FPC cable
  • 1 × 31 pin staggered FPC cable
View all 7 components
View project log
Rich text editor
eli robinson wrote 03/03/2021 at 15:32 point
I would love to see one of the ultra wide bar type displays if possible. TBH I haven't looked at the datasheet to see if any can be driven off of a 4 lane MIPI setup.
LI BO wrote 09/02/2021 at 10:31 point
me either!
harlab wrote 02/08/2021 at 00:32 point
Hi, @maartenvanbever
9 more voices here in comments and it will be manufactured for sale :)
maartenvanbever wrote 02/07/2021 at 07:08 point
i can't find the adaptor on tindie can u give me the url of te page
