+V and -V Display Module for EuroRack/Synthesizer
+V and -V on a RED and Blue Voltage display meter for a Output display for a Control Voltage JOYSTICK or other +/- Voltage source.
let's you display +V and -V voltage on a RED and Blue Voltage display meter for a Output display for a Control Voltage JOYSTICK or other +/- Voltage source.
Main Circuits
•1 x TL072 (Voltage Follower and Inverting Buffer)
•3 Wire Voltage Display that can Display DC 0-100V
The +V (RED)Display just has a simple Voltage follower to buffer the Input signal for accuracy.
The -V (BLUE)Display is wired to a Inverting buffer.
Which inverts the -V into a +V that the display module can read. Results are great much more interactive then just a led indicator.
Search up: DC 0-100V 0.28" 3 Wire LED Voltmeter Digital Display Voltage VOLT METER 12V 24V
for the displays. Pretty Cheap.
Quick prototype on a breadboard. Works Great no problems at all.
Video and Post. https://www.instagram.com/p/CKaX8C_B5LF/
Dark MODE Schematic EuroRack Voltage Display ModuleV1.1.pdf
Adobe Portable Document Format - 45.83 kB - 01/24/2021 at 03:45
Preview
Bright Schematic EuroRack Voltage Display ModuleV1.1.pdf
Adobe Portable Document Format - 45.09 kB - 01/24/2021 at 03:45
Preview
  • 1 × Tl072 Amplifier and Linear ICs / Operational Amplifiers
  • 2 × 3 Wire Voltage Display 2 Wires for power 1 wire for Voltage Reference
  • 2 × 47k Matched Resistor pair (Close as possible) for Inverting Buffer
  • 2 × 1k Electronic Components / Misc. Electronic Components
  • Kinda Shelved this one for now
    Neil Mundt09/28/2024 at 22:26 0 comments
    Still gotta build and use it a bit. This is more of a one off module that has really been put to the side. I might revisit and actually make it into a module who knows. I do have to say aluminium cutting square holes is a big thing so a PCB might be the way to go.
View project log
