In the first live stream we implemented 6 instructions: B, BL, LSLS, MOVS, PUSH, STR - just the bare minimum to run the main loop of the blink example.
Eventually, we got it running in the simulation, and also wrote unit tests for most of these instructions.
You can find the code in the project's repo: https://github.com/wokwi/rp2040js
Now, it's your turn: I'd love to get your feedback about the format, and learn if you want me to do more live-streaming sessions showing how I gradually evolve this project into a usable, general-purpose Raspberry Pi Pico emulator.
Thank you Steve! Next session will probably be on Tuesday same time, I'll post an update about it later this week
I very much enjoyed it. I admire your bravery in streaming this. I get the impression you've not used ARM much before. Regardless, you made good progress in this session, and I look forward to the next one.
