Progress: 64,8% Hardware: v9 Code: v9.8
Update: Time for some pictures of Hardware implementation and UI progress:
Components are mounted on Aluminium heatsink that goes from top to bottom with maximum exposed surfaces to the Airflow.
There are two levels of PCBs in this design. 3x 2S 2A Chargers(?), 4x 3A voltage buck converters, INA219 + INA260, 400w PWM Controller, 2S 20A Protection/Balance Board. Hoping Air will still flow ok.
Also still figuring out the power path for charging.
Progress with the UI:
It's still not very beautiful, but already does almost everything that was planned.
The whole System has a warning Screen for critical Over/Under - Temperature, Voltage, Current, Wetness values and sets everything into Low Power / deepSleep modes.
Phone-like Status Bar for SD card, Logging, Fan, WiFi, Battery, FPS, Lamp, time since reboot.
Small 0.49" Screen cycles through sensor values, shows alarms and indicates charging.
Small 0.49" Screen shows Heart Rate BPM
Small 0.49" Screen shows CO2.
there is also a total VOC screen and a Thermal Cam screen, but im still waiting for the AMG8833.
eBender
