1U Rack Mount for Rpi 4B
A 1U rack mount made exclusively for the Raspberry Pi 4 model B, with OLED Screen, Power switch & Dual HDMI.
Starting from
has orders / reviews
Ships from
When designing our first Rpi rack mount, all we can think about was compatibility. No matter what Pi models you have, we want to make it possible for you to install all of them with one single bracket. As for the second rack mount, we added additional Micro-to-full-size HDMI adapter boards, so you don’t have to buy extra HDMI cables and jacks.
As for the third one, we’ve decided to make it a Pi 4B exclusive, and this time, we are bringing everything to the front.
0.91 Inch OLED Monitor
0.91 inch OLED display on a 1U rack bracket
You don’t have to manually label the Pis any more, there’s a tiny screen displaying the temperature, ip address, CPU and memory usage, it can also be customized to show any information you want.
This isn’t something you can find in a regular or 3D printed rack mount.
All ports at the Front Panel
Repositioned SD cards, power LED & power switch
If you change Micro SD cards a lot, and have suffered from not being able to see the blinking power LED, you will know how important repositioning the slots is. When you ran into hardware issues, these small improvements can save quite some trouble.
Dual HDMI Output
hdmi adapter for 1U rack mount
We've brought out two regular size HDMI ports with a customized type-D-to-type-A connector adapter board, this way you can use normal HDMI cables with any of the Pis, and as usual, they’re bundled with the rackmount.
Power switches
push button switch on a rack mount
To make things better each Pi also gets a latching-style push button switch, you only need to plug the cables once, this will come in handy whenever you need to cut off the power or reboot one of the boards, it makes power management a breeze.
Rack mount all them Pis!
View project log
Ken Yap wrote 03/16/2021 at 03:47 point
Where's the noise generator to make a loud fan sound so that people think you have a very high powered heavy duty rack mount server? 🤣
Justin wrote 02/03/2021 at 20:21 point
I'm curious a) where you are sourcing your Micro HDMI components and b) what your mechanism for attaching them to the PCB is. I've not designed a project with this component yet but am trying to figure this out.
