A cheaper, faster solution for prototyping a cookie cutter was needed. Playdough was the most promising. Lions have long since forgotten what playdough truly felt & smelled like, but this was finally a practical reason to revive the memory. Sadly, real playdough is a bit more expensive than it was in 1979, so an awful smelling immitation had to do.
![](https://cdn.hackaday.io/images/3331071613176367502.jpg)
![](https://cdn.hackaday.io/images/1618391613176378162.jpg)
A single piece mold was the next idea.
![](https://cdn.hackaday.io/images/4753261613176369798.jpg)
Load the dough upside down.
![](https://cdn.hackaday.io/images/9336811613176367886.jpg)
Press on the cookie sheet.
![](https://cdn.hackaday.io/images/7770421613176374708.jpg)
Strip away the excess. The air surprisingly doesn't get trapped in the mold. Not easy to detach the cookie from the mold.
