BlinkLED allows the I2C1 port (e.g. the secnond I2C port on ATmega328pb) to interface with a host SBC.
The i2c-debug firmware can be used to test the I2C1 port, its address is at 0x2A. The Uno clone running i2c-debug has another I2C interface at 0x29.
picocom -b 38400 /dev/ttyUSB0 ... Terminal ready /0/iscan? {"scan":[{"addr":"0x29"},{"addr":"0x2A"}]} /0/iaddr 42 {"address":"0x2A"} /0/ibuff 0,3 {"txBuffer[2]":[{"data":"0x0"},{"data":"0x3"}]} /0/iwrite {"returnCode":"success"}
blinking has stopped
/0/ibuff 0 {"txBuffer[2]":[{"data":"0x0"}]} /0/iread? 2 {"rxBuffer":[{"data":"0x0"},{"data":"0xFC"}]}
Note: I incuded the command byte befor reading the data because I think that is what SMBus does.
