Build a board to store all the components. The bme280 will be in its own compartment away from any heat from the electronics.
Having acces to a laser cutter takes your ideas to the next level.
A project log for N**** Style Home Info System
A Home Info System (a.k.a Clock) Which displays the Time, Date, Humidity, Temperature, Barometric pressure and Moon Phase
