Build guide published
A project log for 3D printable 125mm butterfly valve
A 3D printable servo controllable butterfly valve for my air filter system
fabianFabian 02/07/2021 at 19:560 Comments
You can now find the assembly instructions under the following link.
It contains the STL files, the material list, a few assembly suggestions and also a small NodeRed Flow, which should make it easier to control it via the ESPEasy firmware. :)
