![](https://cdn.hackaday.io/images/8249951647326555272.png)
This is the newest revision of our ESP32-Cam Programmer. The major difference from the previous version is that support dual working voltage (5V and 3.3V). Here is the details of revisions :
- Added a 3.3V Voltage Regulator
![](https://cdn.hackaday.io/images/211991647325928525.png)
- Added voltage selector switch (5V or 3.3V compatible)
One of the nice feature of this new board is a slide switch that allow the board to be configured to either 5V or 3.3V. When it used to program the ESP32-Cam it highly recommended to set to 3.3V. It's saver voltage for the ESP32 as datasheet said. If you want to use this board as a general serial applications such as programming another MCU's like Arduino, there are 6-pins breakout you can use for that purpose
- Compatible with both older and newer ESP32-Cam.
Since there are two kind of ESP32-Cam in the market, so the first design didn't support the newer ESP32-Cam.
![](https://cdn.hackaday.io/images/6960361647327738462.png)
Above is shown the old version of ESP32-Cam. The red marker is GND pin, it is near the LED. As you know this version for some manufacturer reason, they didn't breakout RST pin from ESP32-Cam. As the result we need any tricks to make ESP32 enter the programming mode. Which is why this project was created. But in early 2021, I noticed that the manufacturer has resolved the Reset issue by changing "the red marked pin". That pin can configured as a GND or as a RST pin by moving the resistor jumper into the right position (blue marker) as shown in the image below. The default setting is connected to RST of ESP32.
![](https://cdn.hackaday.io/images/1180651647328335978.png)
The newest ESP32-Cam Programmer are compatible both old and new ESP32-Cam. This is done by keep the associated pin from being connected to any traces.
![](https://cdn.hackaday.io/images/1829561647328840288.png)
- changes PCB shape and color
Here is the bottom side of this board
![](https://cdn.hackaday.io/images/5697471647326977490.png)
