The newest version of the plc io pcb is comming, i used a 10Mbps optocoupler for all 16x input channel and 16x output channel.
The next plc cpu board version will change to use a M.Key NGFF type core board, the cpu is 240MHz Cortex M4 and connect a 1K Lut FPGA
