Hackaday.io Hackaday.io
Sign up Log in
CoilWinder based on grbl for ESP32
This quick project implements a coil winding machine with an ESP32 SoC and two stepper motors.
h2wh2w
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1.6k views
0 comments
8 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
1.6k
0
8
8
Team (1)
  • h2wh2w
Join this project's team
  • CoilWinder based on grbl for ESP32
completed project
MISC
COIL WINDER ESP32 GRBL
This project was created on 02/03/2021 and last updated 4 years ago.
Description
The coil winder software is based on the Grbl Grbl_ESP32 firmware and coilwinder.py script to create .gcode files.Changes from the original Grbl firmware:- coilwinder.h machine configuration with settings for two stepper motors.- report.cpp changed to support a (somewhat clunky) driver for an SSD1306 OLED display. The display is used to show the current CNC statusThe coilgen folder contains a Python script to generate .gcode from a coil's parameters. The gcode file includes a comment with the coil's turn and layer counts, which is displayed on the OLED display.
Details
  • The GRBL base coil winder for ESP32 microcontroller CoilWinder based on grbl for ESP32
  • The G-Code generator implemented with Racket (Lisp) CoilGen
  • The other implementation of the coli winder DIY Coil Winder on ESP32
Log In/Sign up to comment
Sign up with Github
OR
A cryptocurrencies assets monitor based on an esp32 and a waveshare e-ink screen.
Project Owner Contributor
IoT eink Cryptocurrencies monitor
grgory-paulGrégory Paul
This project is an improved Lua SDK, based on ESP-IDF/ESP8266_RTOS_SDK, for Esp32 (comp The hardware , developed by DOIT Team.
LuaNode For ESP32
myembedmyembed
TNC based on ESP32 for Packet radio.
ESP32 KISS TNC
uhpowerupuhpowerup
Dashboard that displays a new Stoic thought everyday!
Stoic Dashboard
ankur-agrawalAnkur Agrawal
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "CoilWinder based on grbl for ESP32", please tell us the reason.
Send message
Remove Member
