Internal body of the device has been assembled, and a battery pack mounted to the plastic shell.
I have designed these two PCBs to mate with just a solder joints, as it turns out, it was a bad decision. The round PCB is a battery charging and monitoring module, flat one is power distribution board that connects to a DC-DC converter circuit, and has few NTCs to monitor battery temp.
