- Front left and right Lead screw (2x): 330mm 304 Stainless Steel Threaded Rod Lead Screw with T8 Brass Nut for 3D Printer, Pitch: 2mm
- Rear Lead screw: (1x) Stock Ender 5 T8, 2mm Pitch Lead screw (Original 370mm, cut to length ¨345mm)
- Stepper Motor Couplings 5x8mm (3x): Kande BW Three Jaws D25L30 Coupler Aluminium Plum Flexible Shaft Coupling Motor Connector CNC Flexible Couplings
- Aluminium Spacer Z-axis Carriages (3x): 8mm x 5mm x L=8mm (From Ender 5 X-axis carriage)
- 3D Printed Carriages Parts: Files | VorEnder 5 Core XY 3D Printer | Hackaday.io
- Components | VorEnder 5 Core XY 3D Printer | Hackaday.io
