Hackaday.io Hackaday.io
Sign up Log in
Poor men's PMU
My adventures with the AD5522 evaluation board
staf-verhaegenStaf Verhaegen
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.4k views
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.4k
0
5
3
Team (1)
  • staf-verhaegenStaf Verhaegen
Join this project's team
  • AD5522 product page
  • AD5522 evaluation board user guide
hardware
ongoing project
This project was created on 02/06/2021 and last updated 6 years ago.
Description
In my previous professional life I had access to so-called source-measurement units. These are devices that allow to do four-quadrant measurement; e.g. they can provide positive or negative voltage and source or sink current. This in all four combination of it without needing to rewire.
Full flex SMU equipment is currently out of my budget and that's why I am looking at the AD5522 SMU chip that should allow to do these type of measurements on a budget.
Project Logs
Collapse
  • Calibration
    Staf Verhaegen • 02/11/2021 at 13:37 • 0 comments
    In part 4 of my journey with the AD5522 evaluation board I now focused on the calibration of the board to get better accuracy. Afterwards I did show measurement accuracy up to a few nA by measuring the photo-sensitivity of the some selected LEDs.
    Find the detail in the blog post.
  • AD5522 eval board setup and first tests
    Staf Verhaegen • 02/06/2021 at 14:44 • 0 comments
    I completed first tests with the development board after avoiding a SPI driver problem. I did use the board now to measure some diodes. I am using python notebooks on a Raspberry to combine measurement with the AD5522 with plotting of the data.
    Details can be found in my blog posts on the topic:
    • part 1: background
    • part 2: board setup, access from Raspberry Pi through SPI, python notebook
    • part 3: measuring some diodes
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
A small, minimal breakout board for the SAMD51
Project Owner Contributor
SAMD51 Minimal Breakout
ben-limBen Lim
WIZnet W5100S + Raspberry Pi Pico + PoE It's a board that I developed. I'm introducing it again because I'm using it for so many projects.
alanAlan
Simple, tiny USB to UART converter, with a splittable galvanic isolator
Debug Board Splittable Isolator
saimonSaimon
Simple Breakout Board for the ATtiny10 Microcontroller
ATtiny10 Development Board
stefan-wagnerStefan Wagner
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Poor men's PMU", please tell us the reason.
Send message
Remove Member
