- Do not look directly into the LED from a near distance!
- Do not give the lamp to children!
- Do not turn on the lamp without a proper metal underground for heat transfer. The lamp itself can get to warm driven by a fully charged battery.
- Heating of the battery will decrease efficiency and can damage your battery. Do not mount the warm magnets directly to the battery without isolation.
- With a full battery and a very small plate the LED can get very hot and you will burn your fingers!
- Strong hits or vibrations to your board can cause the battery or the lamp to fall off. Try to increase your magnetic force by direct magnetic contact on a maximum surface area. Place the magnet on the kingpin and use the stumps to avoid rotation. Fixture your battery with one magnet on the battery and on under the longboard. The magnetic setup will properly not hold in all downhill or freestyle actions. You can also tie the battery with an additional binder and mount the LED directly on the trucks. This should survive most actions J.
- The middle of the beam should point in front of you on the ground. Use a proper optic on your lamp to avoid dazzle of other road users.
- Remove the lamp when you are not using it.
- Don’t lose the magnets or the battery on the road.
