A small test PCB (from a yet unreleased project) is the DUT and contains an ATTINY13A, the reference resistor, a test resistor (screw mounted) and a a temperature sensor. Well, not a proper sensor, but a 3904 SMD transitor whose BE forward voltage changes at about -2.1mV/°C . Both the base and the collector are soldered to GND to improve heat transfer into the transistor. The voltage is measured with a multimeter. The calculated id value is send to the uart TX pin, received by a uart-usb adapter and displayed on terminal on my phone.
The test procedure is simple:
- Initialize the code at room temperature (in my lab 15°C = 0.64V)
- Connect a resistor to test
- Heat up the board with a hot air rework tool until the reported value is incorrect
I've measured three 1% resistors, all of them are edge cases with the worst expected performance:
- 1.0k (0x01): heated up until 0.35V (15°C + 138°C = 152°C) without a change in output value, than the MCU crashed. This is not surprising as it is only rated at up to 125°C. After a power cycle it worked again.
- 4.7k (0x05): heated up until 0.42V (15°C + 104°C = 119°C), then output value changed to 0x04.
- 1.0M (0x1E): heated up until 0.44V (15° + 95°C = 110°C), then output value changed to 0x1D.
Although this is not a precise test by any means, I'm very happy that the results exceeded my expectations. I'm confident that the code will work on most AVRs reasonably reliable until 70°C, maybe 85°C. For critical applications where an incorrect detection could lead to permanent damage I'd still recommend to only use the even values and interpret all odd ones as an error.
