Hackaday.io Hackaday.io
Sign up Log in
Cheap-ass oscilloscope LC tester
LC tester, basic components from an old PSU
ali6x944Ali6x944
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
97
0
1
1
Team (1)
  • ali6x944Ali6x944
Join this project's team
  • w2aew video
  • EDN's Glen Chenier article
hardware
completed project
LC TESTER oscilloscope RC network LC TANK cheap
This project was created on 02/09/2021 and last updated 5 years ago.
Description
So it was something like, I need more testing equipment *staring at LC testers*
after a bit of screwing about, an adapted version of w2aew adaptation of -I assume EDN's Glen Chenier's - LC tester/test method was made, where we have a fast-edge essentially used to "ring" an LC tank circuit to test inductance, and "fill" a RC network to test for capacitance, trick is keeping one of the parts in this setup well characterized and using a super duper fast-edge.
w2aew used the gr8 74AC14 to make the fast-edges, but I'm broke so I had to salvage my way through this one, and basically started plucking components from a dead PSU and cobbled up this monstrosity, with just an LM339 & 7805 + a cocktail of passives. tbh it is not the best thing in the world but it does its job fairly well...
plz goto:
https://www.youtube.com/watch?v=74fz9iwZ_sM
Project Logs
Collapse
  • Construction
    Ali6x944 • 02/20/2021 at 19:04 • 0 comments
    IRL board
View project log
Log In/Sign up to comment
Sign up with Github
OR
Two jigs to assist in flexural testing and ensuring proper and repeatable alignment
Project Owner Contributor
Flex Test Alignment Jigs
patrickPatrick
This project includes info I've used to use to simulate Nand2Tetris (Compiling Verilog to C++ and using a test bench in C++)
Nand to Tetris in Verilog Part 2 - Verilator
ariaAria
I decided to see if K’nex can be co-opted for science and used them to build a test tube rack.
K'nex Test Tube Rack
steve-schulerSteve Schuler
The 2015 Hackaday Prize
A minimalist direct conversion radio receiver. 4 general purpose transistors and a Polyakov 2 diode mixer.
PolyMorph Receiver
morphmorph
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Cheap-ass oscilloscope LC tester", please tell us the reason.
Send message
Remove Member
