Hackaday.io Hackaday.io
Sign up Log in
Cheap-ass oscilloscope LC tester
LC tester, basic components from an old PSU
ali6x944Ali6x944
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
97
0
1
1
Team (1)
  • ali6x944Ali6x944
Join this project's team
  • w2aew video
  • EDN's Glen Chenier article
hardware
completed project
LC TESTER oscilloscope RC network LC TANK cheap
This project was created on 02/09/2021 and last updated 5 years ago.
Description
So it was something like, I need more testing equipment *staring at LC testers*
after a bit of screwing about, an adapted version of w2aew adaptation of -I assume EDN's Glen Chenier's - LC tester/test method was made, where we have a fast-edge essentially used to "ring" an LC tank circuit to test inductance, and "fill" a RC network to test for capacitance, trick is keeping one of the parts in this setup well characterized and using a super duper fast-edge.
w2aew used the gr8 74AC14 to make the fast-edges, but I'm broke so I had to salvage my way through this one, and basically started plucking components from a dead PSU and cobbled up this monstrosity, with just an LM339 & 7805 + a cocktail of passives. tbh it is not the best thing in the world but it does its job fairly well...
plz goto:
https://www.youtube.com/watch?v=74fz9iwZ_sM
Project Logs
Collapse
  • Construction
    Ali6x944 • 02/20/2021 at 19:04 • 0 comments
    IRL board
View project log
Log In/Sign up to comment
Sign up with Github
OR
No fancy AI based detection, just detecting when two pieces of metal are shorted
Project Owner Contributor
Target hit detection
mcunerdmcu_nerd
Vaguely based off of the exoskeleton from Elysium
Pneumatic Exoskeleton
james-hobsonJames Hobson
I decided to see if K’nex can be co-opted for science and used them to build a test tube rack.
K'nex Test Tube Rack
steve-schulerSteve Schuler
This project includes info I've used to use to simulate Nand2Tetris (Compiling Verilog to C++ and using a test bench in C++)
Nand to Tetris in Verilog Part 2 - Verilator
ariaAria
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Cheap-ass oscilloscope LC tester", please tell us the reason.
Send message
Remove Member
