The SGT1 address multiplexer analysis​
A project log for STEbus 6845+6803 video board
Reverse engineering a colour graphics video board
keithKeith 11/02/2022 at 23:260 Comments
The 4-to-1 bit multiplexers select input bits based on signals B and A.
"B" is VCYC inverted.
"A", the Row/Column selector, is /RAS clocked by the 28 MHz master clock.
This is /RAS delayed by 1/28th of a microsecond, which is 35 ns.
/CAS is /RAS clocked by CY3, which is half the 28 MHz master clock.
This is /RAS delayed by 1/14th of a microsecond which is 71 ns.
DRAM cycle frequency is 28/8 = 3.5 MHz.
inout
video (VCYC=1)mpu (VCYC=0)
rowcolrowcol
ra0ma5a0a8xa0
ra1ma6a1a9xa1
ra2ma7a2a10xa2
ma0ma8a3a11xa3
ma1ma9a4a12xa4
ma2ma10a5a13xa5
ma3ma11a6a14xa6
ma4ma12a7a15xa7
