After I got the lid off, the antenna was in full display. There was about 7 screws holding the antenna to the aluminum base. I still couldn't pull the whole unit out to see the electronics, but i knew they were there. I unscrewed the antenna but it had a soldered connection in the middle. I hooked up my soldering iron and unsoldered that. The antenna came off and there was a nut on the bottom where the antenna feed through to the electronics. I tried tied to pull it apart once more after undoing the nut but still no luck. I took a knife and scrapped off some of residual foam and found the screws holding the shield (my guess anyway) to the casing. I undid the screws and shield came apart. I finally got to the electronics. I decided to take a break at this point and pack it up for the evening. Next time I will do some exploring into how this thing works and what i can do with it, if anything
![](https://cdn.hackaday.io/images/972151612939342149.jpg)
![](https://cdn.hackaday.io/images/7707351612940149337.jpg)
![](https://cdn.hackaday.io/images/1286081612940231813.jpg)
