Drill bearing race test
A project log for Dual-Disc Polar Printer
alpha and beta instead of x and y
heinzheinz 05/02/2021 at 18:561 Comment
I'm thinking about connecting the two bigger bearings with screws, but unlike the lazy suzan bearings I have to drill holes for that.
I had no success with a cobalt drill, but tried a resharpened masonary drill and it worked better then expected.
Ordered a 3mm masonary and will grind it down to 2mm to maybe cut a hole in the outer race from top to bottom without entering the ball groove.
Rich text editor
Paul McClay wrote 07/02/2021 at 07:35 point
relieved that it turned out to be someone else making all the noise...
