Hackaday.io Hackaday.io
Sign up Log in
Home Lab Easy Kit
This project will help amateurs how want to make home project with use of STM32F103 (blue pill) connected to Raspberry Pi via I2C.
osharudaosharuda
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 1
View Gallery
314
1
2
2
Team (1)
  • osharudaosharuda
Join this project's team
  • Home Lab Easy Kit
completed project
Software
hardware
STM32 raspberrypi
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 02/10/2021 and last updated 6 years ago.
Description
This project allows to use some STM32F103C8T6 peripherals with Linux based microcomputers like Raspberry Pi using I2C bus.Purpose for Home Lab Easy Kit project is to give amateurs possibility to build experimental setups easier and to save time for other more important objectives like experiment logic, calculations, etc. Read more details on https://github.com/osharuda/home-lab-easy-kit
Components
  • 1 × STM32F103C8T6 (Blue Pill)
  • 1 × Raspberry Pi
  • 1 × SIM800L
  • 1 × LCD1602a
  • 1 × A4998
View all 6 components
Build Instructions
Collapse
  • 1
    Step 1
    All instructions are available on GitHub project repository: https://github.com/osharuda/home-lab-easy-kit
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
[deleted]
osharuda wrote 04/01/2021 at 21:54 • point
Thank you very much. The initial purpose for this project was self education. Later I decided to extend it so others may use, but initially I started it for my own purposes. Lab safety is a real thing, and many people without any knowledge play with really dangerous things, like stepper motors or lasers. Steppers may cause fire, lasers may harm retina, power supply without proper grounding may kill. These kind of things spreading among amateurs quickly, so any notice about potential danger may save someone.
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Home Lab Easy Kit", please tell us the reason.
Send message
Remove Member
