This debugging tool monitors the bus signals. If you access a bus address where there is no slave, the master should drive the bus indefinitely. You can also detect if it is accessing the addresses you expect.
Files
STELA_article_Wireless_World.htm.zip
A brief article by the designer, from Wireless World, August 1988.
