Today, I spent some time making major changes to the code. I really wanted more control over what's happening when when, I also wanted to make it a bit more versatile and also safe.
I added
- Wizard guided flow
- the ability to restore the eeprom from an existing binary file
- an option to verify what has been written to the eeprom
- fixed a bug with passwords shorter than seven characters
- added the ability to select the i2c bus on the beaglebone black
- added option to remove the password completely or chance to a new one
- added status bars for the read, write, and verify operations
The entire workflow of one session can be seen here:
EEPROM Tool - Crack your favorite laptop - hopefully without breaking it... Author: Copyright 2021 - Timo Birnschein Please select task: restore EEPROM from file: type <restore>, or read, modify and write system EEPROM: type <modify> (default is <modify>) What i2c bus / SMBus would you like to use? Default is <2>: Selecting I2C bus 2 Press Enter to read EEPROM contents... Reading from EEPROM... Reading EEPROM: |██████████████████████████████████████████████████| 100.0% Complete Writing binary to file... eeprom.bin Extracting and translating password: hallo Checksum of password as read from eeprom: 0xa5 Confirmation passcode (should be the same): hallo Checksum of re-entered password as read from eeprom: 0xa5 Calculating own checksum: 0xa5 The above password might not be correct as your system might use a different encryption scheme! If the password does not work, writing a new password also won't work! Only removing it altogether will work. Choices are: remove existing password from EEPROM or write a new password to the EEPROM Type <remove> or <new> without brackets and hit enter. If you just hit enter, the program will exit. remove Writing and encoding new password: Checksum added to eeprom: 0x0 Writing confirmation password (must be the same): Adding checksum to confirmation password: 0x0 Writing binary to file... eeprom_mod.bin Do you really want to write to the EEPROM of your computer? ************** THIS MIGHT BRICK YOUR LAPTOP!!! ************** Type: and hit enter (case sensitive, no brackets!)... Yes I want to Writing binary file back into EEPROM, length: 256 Writing EEPROM: |██████████████████████████████████████████████████| 100.0% Complete Reading EEPROM back for verification... Reading EEPROM: |██████████████████████████████████████████████████| 100.0% Complete Writing binary to file... eeprom_verify.bin Verifing EEPROM: |██████████████████████████████████████████████████| 100.0% Complete Verification completed. EEPROM seems good. No guarantees! Done. Bye.
I tested this using my 256 byte 24C02 instead of flashing my laptop a hundred times. This also led to me changing the address the script accesses to only 0x57 which is where the supervisor password is located. Eventually, I would like to blow this up even more by reading and writing the entire 24RF08 again but for only the supervisor password that's not required.
I still don't know where all the other passwords and features are. Unfortunately, there is no nicely documented summary available - at least not as far as I know. If someone has one, please let me know. We could make this into a fully configurable toolkit if we wanted to. Similar to the Lenovo service diskette that allows setting serial numbers and owners and the like.
Btw: Code is here now: https://github.com/McNugget6750/x201Password
Maybe at some point I might look into this menu system a bit more: https://www.daniweb.com/programming/software-development/code/309413/console-application-menu-module
