In a nutshell:
- For the Amstrad / Schneider CPC range of 8bit home computers
- Made possible by sponsoring and initiative from the one and only, legendary Future Man - TFM! https://futureos.cpc-live.com/
- Exclusive Limited Edition - by invitation only
- RSX ROM, software suite, and manuals by TFM
- Hardware & firmware bv LambdaMikel
- Github: https://github.com/lambdamikel/LambdaSpeak-FS
Features:
- Perfect speech synthesis: Epson S1V30120-based natural speech
- DECtalk & Epson speech synthesizer modes
- English & Spanish speaking, different voices, DECtalk singing, ...
- MP3 player (from SD card)
- Battery-buffered Real Time Clock with thermometer
- Audio routing options for left / right stereo channel mixing & assignment:
Audio from CPC speaker or external amplifier - High quality Amdrum PCM sample playing mode:
at least Digiblaster quality - 70 new RSX commands for BASIC
- CP/M support (speech, real time clock)
- UART / Serial Interface up to 115200 Baud
- MIDI IN and OUT
- 8 easy to control GPIOs with LED Segment Bar for lightshows etc.
- FutureOS support
- 2 DKSs of software
- Users Guide & Technical Reference Manual available
- MX4 Connector
- Help & Support by TFM & LambdaMikel
- Open Source
Schematics
![](https://cdn.hackaday.io/images/3852701623966948575.png)
BOM
Resistors
- R7: 2k; note: must match D1 LED!
- R1, R3, R4: 10k
- R5: Jumper Wire
- Rn: 9pin Resistor Array / Network, A102J
Potentiometers / Trimmers:
- RV1: 100 Ohm (Code 101)
- RV2: 50k Ohm (Code 503)
Capacitors
- C1, C2: 22 pF (Code 220); note: these must match Q1!
- C3: 68 nF (Code 683)
- C5, C6, C7, C8: 100 nF (Code 104)
- C9, C10: Jumper Wire
ICs
- U1: GAL 22V10(B,D)
- U2: 74LS374
- U3: 74LS244
- U4: ATmega 644-20PU
- Optional: DIL sockets for ICs (I recommend to use a socket at least for U4, to allow reprogramming)
Misc
- CPC Connector: 2.54mm 2X25 50 Pin Right Angle Male Shrouded PCB Box Header IDC Connector
- Q1: 16 MHz Crystal
- SW3: 8 Position DIP Switch
- D1: Activity LED
- J8: 8 Segment LED Bar Display
- J2, J3: 2.54mm Pitch 8 Pin Single Row Straight Female Header Socket Connector for Arduino Shield (mikroBUS connector)
- J7: Breakable Single Row Arduino Pin Headers
- J4, J5: Mini Stereo Audio Sockets
- J1: Optional Barrel Jack Power Connector
Modules
- J2, J3: TextToSpeech board
- MP3 / UART: MP3 UART Module
- RTC / I2C: RTC IIC Module
- CR2032 3V Battery for RTC Module
- Mini SDCard for MP3 Module
- Mini Stereo Audio Patch Cable
Assembly Tipps
- Don't forget the decoupling capacitors (104's) under the ICs!
- If you are going to socket the ICs, then you will need to cut out the middle struts from the DIL sockets to accomodate them.
- Use a fine side cutter to cut off the
SQW
and32K
pins from the RTC module
Videos
