2021-02-25
Ordered the last one in stock from a German supplier. 12.5 euros = £10.76.
This is much cheaper than the only one I can see on eBay, which is $54.32 (Approximately £38.53) plus $23.99 (approx. £17.02) postage (c. £55.55 total).
Since this part is so scarce, it is not worth designing a board specifically for it.
The pinning is very similar to the 32016, so a board that supports both devices would be sensible.
2020-03-06
Device arrives.
2021-04-13
Vince's two spare boards arrived this morning. That should certainly save me a lot of prototyping time. I need to order some sockets...
2022-05-14
I now have a selection of sockets for the major chips. The UART PCB corrections and socket modifications will be made. The Timing Control Unit needs a surface-mount capacitor fitting underneath the socket.
2022-06-17
Looking at fitting logic chips. I need:
3 x 74HCT573 transparent latches for address lines
1 x 74LS245 buffer for data bus
3 x 74LS32 quad OR gate
1 x 74LS04 hex inverter
1 x 74LS14 hex inverter with Schmitt triggers
6 other chips whose type I cannot read on photographs.
There is no parts identification in the PCB manufacturing files, or PCB legend, and there is no circuit diagram.
2023-03-11
Decided to check what chips I have.
NS32016N-10 CPU in plastic DIP48
NS32082D-10 in ceramic DIP48
NS32202D-10 (2) in ceramic DIP40
NS32081D-10 in ceramic DIP24
NS32C201D-10 in ceramic DIP24
NS32381U-25 in ceramic PGA
NS32382U-15 in ceramic PGA
NS32CG16V-10 in plastic PLCC68
