This is a quick guide on how do you simulate U8G2 on PC.
This is a guide to install Cygwin and its required tools. https://mindchasers.com/dev/openocd-darsena-windows.
Be sure to obtain the Development Libraries, and select the one with MinGW:
1.) Copy the library files from the x86_64-w64-mingw32/lib to C:/cygwin64/lib:
2.) Copy the entire SDL2 folder from /x86_64-w64-mingw2/include into c:/cygwin64/lib/gcc/x86_64-pc-cygwin/10/include:
Make sure the SDL2 folder is inside that include directory. Do not copy all its contents into the include folder - just put the folder inside.
3.) Finally, copy the x86_64-w64-ming32/bin/*.* to the C:/cygwin64/bin:
View all 11 instructions
Vanshaj
agp.cooper
Melissa LeBlanc-Williams
Colin Conway
Yes, delete it Cancel
You are about to report the project "Simulate U8G2 on PC!", please tell us the reason.
