This is the first of my weekly PCB challenge projects, an electric piano soldering kit. It was based on drj113's Stylophone design, with a couple of extra features I added, including;
- larger, louder speaker
- toggle between the onboard speaker and a 3.5mm audio jack output
- modified resistor chain that uses more common values
- a new piano key layout designed in Fusion 360
- A removable stylus with a banana jack
Jim Heaney
Joel Lewis
alpha_ninja
