3D printed Kaleidoscope
A 3D printed Kaleidoscope with easy to change disks
Public Chat
This is a 3D printed 3-mirror Kaleidoscope that uses customizable disks so you can put whatever you want inside. It works best with transparent or translucent materials, opaque materials won't look as good. Colored glass, beads, flower petals all work great!
This is a 3D printed Kaleidoscope.
It uses $10 in material to make, has good image quality, and it's easy to change the contents of the kaleidoscope.
Kaleidoscope_body.stl
Standard Tesselated Geometry - 8.92 MB - 02/21/2021 at 17:15
Download
Kaleidoscope_turret.stl
Standard Tesselated Geometry - 201.94 kB - 02/21/2021 at 17:14
Download
Kaleidoscope_spacer.stl
Standard Tesselated Geometry - 118.44 kB - 02/21/2021 at 17:14
Download
  • 1
    Print the three 3D parts
    Print these in decent quality as the rotation of the Kaleidoscope will work much better with high quality prints.  I printed these slow, taking ~12 hours to print all 3 parts in black PLA
  • 2
    Tape mirrors together in a triangle configuration
    I bought 2" x 6" glass mirrors off of Amazon for $15 for a 10pack.
    Use scotch tape (thick tape like masking tape won't fit in the housing) to tape them in a triangle configuration
    Slide the mirrors into the kaleidoscope - it is a tight fit, wiggle them around to get it to go!
  • 3
    Put the rotating turret on
    Look for the triangles to align this and slide it on.  It should rotate freely.
View all 5 instructions
brucejdii wrote 03/06/2021 at 01:13 point
This is awesome!   SO simple!  Yet, I never woulda figured it out on my own!!!
Lex Kravitz wrote 03/14/2021 at 20:49 point
Thanks for the comment hope you enjoy it!
