Since the project is about making a functional part for a Lubitel camera, a rather precise device, and a 3D printer is the final step of manufacture, the printer should be capable of delivering enough precision.
I developed the 3D model without any special requirements for the printer in mind. Also, taking into account the choice of filament, which has no issue with adhesion, I assume that any conventional 3D printer should work. Direct drive extruders are preferred though - I chose Prusa.
