I was curious what the impact would be on the overall power consumption. I plotted a comparsion between the voltage drop via 24 MHz & 48 MHz.
Seems that the 48MHz consumes less power as the device spends a larger part of the time in sleep mode.A project log for Solar powered Bluetooth Thermometer with Supercap
Run Xiaomi Thermometer LYWSD03MMC with a supercapacitor and mini solarpanel.
