Supplies are operational!
A project log for Amplifier input select, pre-amp and tone control
A fully digitally I2C-controlled input selector, pre-amplifier and tone controller based around the TDA7439.
tijl-schepensTijl Schepens 03/18/2021 at 19:450 Comments
So today I finally got around soldering the board.
A first power-up shows that the 9 V and 3.3 V LDOs are working as expected. It also shows that I made a stupid mistake...
I added R23 in the schematic and populated it thinking that if the gate of the transistor is pulled to 3.3 V, the regulators would be disabled by default. Of course that cannot work as you cannot generate 3.3 V if you disable the regulator (duh!).
So instead either R1 has to be populated to enable all regulators by default, or an external pull-up from another 3.3 V supply needs to keep the gate high to disable the regulators.
So now that the board is soldered and the regulators are ok, I can fire up my Raspberry Pi and see if the I2C is working. Fingers crossed!
Rich text editor
