First debugging
A project log for wind weather station
This is a product match the anemometer to measure the wind speed, also provide other interfaces and sensor to measure tem, hum, and so on.
makerfabsMakerfabs 03/13/2021 at 11:400 Comments
I have finished the debugging of the components. Fortunately, all the components seem no problem and worked normally.
After downloading the firmware to the controller, I used the testing code written by Arduino to debug the sensor--DHT11, BMP280, and so on. As the picture:
